*sortentity()
Changes the order that entities are output in the corresponding *entity() block.
*sortentity (entity_type, order)
HyperMesh Template Command
Currently only supported for the LS-DYNA user profile. If used in any other user profile, the command will error out stating “*sortentity is supported for Dyna user profile only”.
- entity_type
- The type of entity to sort.
- order
- Valid values are:
To output parameters based on their ID:
*sortentity(parameters,byid)
*parameters()
*format()
*string("*parameter(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(")")
*end()
*output()
Version History
2020
