*sets()
Starts a set block.
*sets (?card_image_name?, ?idpool_name?,?subentity_idpool_name?)
HyperMesh Template Command
Starts a set block. Sets with a card image matching the specified card image name are considered for the block.
This command must be accompanied by an *output() command at the end of the block.
- card_image_name
- An optional 32-character string enclosed in double quotes that defines the card image name of the sets in the block. If not needed, use double quotes "" or omit the argument.
- idpool_name
- An optional 32-character string enclosed in double quotes that defines the name of the ID pool that the sets belong to. If not needed, use double quotes "" or omit the argument.
- subentity_idpool_name
- An optional 32-character string enclosed in double quotes that defines the name of the ID pool that the entities in the set must belong to. If not needed, use double quotes "" or omit the argument.
To write out all sets with the format:
*set(id,"name",color,"typename",ordered)
*setid(entity 1 ID)
*setid(entity 2 ID)
*sets()
*format()
*string("*set(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(",")
*field(integer,color,0)
*string(",")
*field(quotedstring,typename,0)
*string(",")
*field(integer,ordered,0)
*string(")")
*end()
*counterset(counter1,0)
*loopif([counter1 != idsmax])
*pointerset(pointer1,ids,counter1)
*string("*setid(")
*field(integer,pointer1.pointervalue,0)
*string(")")
*end()
*counterinc(counter1)
*endloop()
*output()
