*legends()
Starts a legends block.
*legends (config)
HyperMesh Template Command
This command must be accompanied by a *output() command at the end of the block.
- config
- An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out legends and their associated objects:
*legends()
*format()
*string("*legends(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(")")
*end()
*output()
Incorrect usage results in an import error.
Version History
2022.1
