*timestepcontrols()
Starts a timestepcontrol block.
*timestepcontrols (config)
HyperMesh Template Command
This command must be accompanied by a *output() command at the end of the block.
- config
- An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out all timestepcontrols with the format:
*timestepcontrols(id,"name")
*timestepcontrols()
*format()
*string("*timestepcontrols(")
*field(integer,id,0)
*string(",")
*field(quotedstring,name,0)
*string(")")
*end()
*output()
Version History
2021
