*groups()
Starts a group output block. The groups in the HyperMesh database whose configuration and type are equal to the parameters are output according to the user-defined format in this block.
*groups (configuration, type, user name)
HyperMesh Template Command
configuration
Defines the HyperMesh group that should be output using this block definition. The possible values are:
ConfigGroup Output
1 Interface with main and secondary elements
2 Interface with main elements and secondary nodes
3 Interface with secondary elements
4 Interface with secondary nodes
5 Rigid walls
type
Defines the group type that should be output using this block definition. The possible values are user-defined so that more types can be defined by the user. When groups are built, the template file is read automatically to determine the type of the group.
user name
A 32-character string enclosed in double quotes holding the name of the group as defined by the user. The name is used by the appropriate panels and displayed to the user for selection.
Requires an *output() command at the end of the block.
