*specialidruletoignoreincomingids()
Sets an ID pool to ignore incoming IDs for when there is an ID range defined.
*specialidruletoignoreincomingids (entity_type, pool_id)
HyperMesh Template Command
This is applicable for entities without and ID definition in the deck.
- entity_type
- The type of entity to consider.
- pool_id
- The solver ID pool number to use.
To ignore the incoming element IDs on the CONSTRAINED_NODAL_RIGIDBODY_IDPOOL ID pool (13) in the LS-DYNA user profile:
*specialidruletoignoreincomingids(elements, 13)
Version History
2017
