View Controls
Use the View toolbar to control the view and display of your plot, the curve color display, and plot curves instantly.
Fit Options
- From the View toolbar, click .
- From the pop out menu:
- Click to fit x data only within the viewable graphics area.
- Click to fit y data only within the viewable graphics area.
- Click to flip x and y data.
For Bar Charts, this option flips the axes and creates horizontal category labels.
- Click to enable Curve Inspect Mode.
Curve Color Mode
From the View toolbar, use the curve color mode options to change curve colors.Select
to display the following options:- Multi Window
- Click the multi window icon to change the color modes across multiple windows in a page with a single click.
- Default
- Adopt the default curve colors. A separate color is displayed for each curve in the window.
- File
- Change color modes across multiple windows on a page or a single window based on the file name, rendering one color for all curves.
- Axis
- Change color modes across multiple windows on a page or single window based on the axis color. If multiple axes exist, the curve color is changed with the axis color.
- Layer
- Change color modes across multiple windows on a page or a single window based on a report template. If multiple report templates exist, one color for each curve in a report is rendered.
Dynamic Results Plotting
From the View toolbar, click Dynamic results plotting, , to plot curves instantly while the solver is running. When selected, the following micro dialog is displayed:
From the micro dialog, you can change the time interval to plot the results. HyperGraph updates the results dynamically based on the time interval selected.
- In the For Every field, enter a value or click the up or down arrows to increase or decrease the refresh interval value by 10.
- Click to apply the changes or to reset the defaults.
