Statistics
Calculates statistics over a specified range on a curve.
From the Line Chart ribbon, click the Statistics tool.
Template List
Statistics can also be generated from Templex templates. The Templates list allows you to edit and save a template supplied with the program or you can create and save a new template. The current template is displayed in the Template field.
Add/Delete
Click Add to add a new template or Delete to delete a template from the list.
Open
Click the file open icon to load a template and display it in the text box.
Save
Click the save icon to save template changes. You can either save the template with the same name or give it a new name.
Edit
Controls text editing in the text box.
Activate the Edit check box to edit text.
Deactivate the Edit check box to disable editing capabilities and display evaluated Templex statements.
Find Point Controls
Click:
To find:
or
Left-most or right-most end point.
or
Next point to the left or right.
Global maximum of the curve.
or
Next local maximum to the left or right.
Global minimum of the curve.
or
Next local minimum to the left or right.
Next Curve
Corresponding point on the next curve.
