HyperWorks
HyperWorks
2023
  1. Home
  2. Multibody Modeling
  3. MotionView Overview
  4. Model File Management
    Open and save model files, import/export models, and import/export a solver deck.
  5. Importing and Exporting a Solver Deck
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
HyperWorks
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
    • MotionView Overview
      • End User Workflow
        A multibody system study generally involves the following broad steps. The following sections give a brief introduction on using MotionView and the related products to conduct such a study:
      • Model File Management
        • Opening and Saving a Model File
          MBD model files are files written using the Model Definition Language (MDL). These model files (*.mdl) can then be opened and saved in MotionView.
        • Importing and Exporting Models
          The import feature facilitates reading in systems from the wizard library, or the MDL data statements (properties), or a combination of the two using an MDL file. The export feature facilitates exporting wizard selection choices in the existing model and/or the MDL data statements (properties), or a combination of the two into an MDL file.
        • Importing and Exporting a Solver Deck
          • Importing a Solver Deck
          • Export a Solver Deck
          • Load an ADAMS *.adm File
      • Model Entities
        Learn more about MotionView model entities.
      • Container Entities
        MotionView supports and encourages a modular model building approach. Different entities can be aggregated into containers, thereby arranging a model into a collection of different assemblies or sub-systems.
      • Collectors
        A collector is a yellow button on a panel that enables you to select an entity type either graphically or from the topics/motionview/collectors_select_entity_dialog_r.html.
      • Data Entry
        Explore data entry in MotionView.
      • Use the Expression Builder
        The expression builder allows you to enter expressions in text boxes without extensive typing and memorization. It can be used to construct mathematical expressions that are a function of the model parameters.
      • SolverMode
        MotionView contains an implicit variable called SolverMode. In MDL, SolverMode can be used in an "if" context to define topology (include Templex templates). MotionView retains the "if" result for both cases so that when you toggle the solver type, the associated text becomes active within the user interface.
      • Select an "Entity" Dialog
        The Select an "Entity" dialog allows you to change the entity in a collector.
      • MotionView in Batch Mode
        Batch mode allows you to generate a solver input model file from an MDL model file and run the solver job without starting the MotionView user interface.
      • Export Data
        The Export Data dialog allows you to export your data to an Excel or text file.
      • Data Summary
        The Data Summary dialog displays model data in a table that can be edited.
      • Methods of Orientation
        Coordinate systems in MotionView can be oriented using a variety of methods.
      • Implicit Graphics
        Implicit graphics can be displayed for all applicable entities, allowing you to visualize their location and orientation.
      • Check Model
        Check Model searches for unresolved references and invalid data in the model. If errors in the model are detected, it is reported in the message window that is displayed when the check is completed.
      • Create Deformable Surfaces from FEM
        The Create Deformable Surface From FEM macro enables you to quickly create a matrix of explicit markers to be used in defining a deformable surface.
      • MotionView Panels/Tools
        Explore the various panels and tools in MotionView.
      • Command Sets
        The Command Sets panel allows you to create command sets for the solver-command file. The command sets for a model are order dependent, since they define the contents of the solver command file.
      • Forms
        Use the Forms tool to edit general data entry forms.
    • Model Browser
    • MotionView Ribbons
    • MotionView CAD Interfacing
    • Flexible Bodies
      MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
    • Functional Mockup Unit (FMU)
      Add an FMU to the model or export a model as an FMU.
    • Vehicle Modeling
    • Tcl/Tk Reference Guide
      Reference material for the scripting interface which is a set of Tcl/Tk commands.
    • MDL Reference Guide
    • MotionSolve Reference Guide
    • Templex and Math Reference Guide
    • MotionView Python Reference Guide
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023
  1. Home
  2. ...
  3. Importing and Exporting a Solver Deck
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
ON THIS PAGE
    ON THIS PAGE
