Pulse Steering
A Pulse steering event simulates a vehicle response to a sudden pulse input to the steering wheel while driving in a straight line at a constant speed.
It is used to characterize the dynamic response of the vehicle with the results typically analyzed in the frequency domain to identify resonant frequencies of the vehicle. The vehicle is driven with a fixed steering wheel angle for approximately 10 seconds before and after the pulse event in order to provide sufficient data to the frequency analysis.
The event follows the ISO +7401-2003 – Road Vehicles-Lateral transient response test methods-Open-loop test methods. The pulse can be input as a sine, step, or ramp function. The Altair Driver is used to maintain a constant speed, and standard outputs for the vehicle and tires are included in the tire and output requests systems.
The pulse steering event is supported by the Cars & Small Trucks, Heavy Trucks, and Two-Wheeler vehicle libraries. Automated output reports are available to plot the results.
Parameter Name | Description |
Units | Describes the Length, Velocity, and Acceleration units.
Velocity | Velocity the vehicle maintains during the event. |
Steer input * | The magnitude of the steering input that is applied, in degrees. |
Lean input ** | The magnitude of the demand lean input, in degrees. |
Length of pulse | The length of the steering pulse in seconds. |
Function Type | The function type used in the pulse steer portion of the event. Options: Sine, Step, and Ramp. |
Steer input time * | The absolute time in seconds when the steer pulse reaches its maximum angle. |
Lean input time ** | The absolute time in seconds when the demand lean pulse reaches its maximum angle. |
End time | Absolute end time of the event, in seconds. |
*Applicable only for Cars/Trucks i.e., Non-leaning events.
**Applicable only for Two-wheeler i.e., Leaning events.
Controller Settings
- Non-leaning events (Cars/Trucks)
- LONGITUDINAL – TRACTION CONTROLLER SETTINGS
- Use additional control: Enables the additional feedback control for the traction
control. The gains for the controller can be edited by toggling this check
box.
Kp Proportional gain for the feedback PID controller Ki Integral gain for the feedback PID controller Kd Derivative gain for the feedback PID controller
box.
- Leaning events (Two-wheelers)
box.
box.
Signal Settings
Use the signal settings to set minimum, maximum, smooth frequency and initial values for Steering, Throttle, Brake, Gear, and Clutch signals output by the driver.
The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Road Settings
- Flat Road
- Uses a flat smooth road for the event with no required road file.When the Flat Road is selected, the Graphics Setting option is available with the following parameters:
- View path centerline: Enables the visualization of the event path.
- This check box is disabled for open loop events without a path.
- View grid graphics: Enables the visualization of the road grid graphics.
- When view grid graphics check box is toggled, road grid parameters can be edited in the Grid Settings tab.
Grid length Defines the length of the road. Enter a positive value in the model units. Grid Width Defines the width of the road. Enter a positive value in the model units. Grid X offset Gives a distance offset to the road graphics in the longitudinal direction. Enter a positive value in the model units. Grid Y offset Gives a distance offset to the road graphics in the lateral direction. Enter a positive value in the model units.
- Road File
- The road file option enables the selection of a road file to be used in the event. Using this option, all tires in the model consider the event specified road file instead of the file included in the tire entities.
- Tires
- Using Tire as road selection option, the road file specified in the tire entity is used in the events simulation.
Automated Output Report
Report Name | Report Signals |
Yaw Rate and Vehicle CG Displacement |
Steering Input |
