BCElemToSet
Aggregates element values to sets.
src
An element value table.
sets
A set entity table.
aggregate
An aggregation mode (avg, sum, min, max, extreme).
pool_name
Name of the element pool in the set.
Outputs
answer
An set value table.
  • If src is a vector or tensor table, it should be transformed to the global coordinate system.
  • min, max, and extreme aggregate modes are valid only for scalar data.
  • The Expression Builder will auto-fill pool_name with @current_pool (assigned by the application).
  • It is not possible to plot set-bound values in HyperView. A set-bound value must be assigned to elements using BCSetToElem.
BCElemToSet(src,sets,max)
XML Example
<call name="BCElemToSet" src="src_tab" sets="set_tab"
pool_name="shell" aggregate="max" answer="ans_tab" />
