Add Metadata
Add metadata to all types of entities. The added metadata can be saved to an *.hm file.
By right-clicking on the any metadata, it can be added as a browser column in the supported entity views for bulk reviewing or editing.
Explore the user interface.
View controls enable you to control the view and display of your model in the modeling window.
Quickly find and open the tools and browsers that are available from the ribbons, as well as create entities and solver cards.
Select and deselect entities to modify with other tools. Selected entities are outlined to indicate their selection state.
Translate, rotate, and align the model.
Use the Measure tool to measure length, angles, radii, areas, volumes, centers of gravity, and bounding boxes.
Learn how to manipulate entities.
Learn the basics of working with entities.
Learn how to work with entities using the Entity Editor.
Define the mandatory, default value, and/or hidden state settings for entity attributes.
Use the tools in the Home ribbon group menu to transform, mirror/reflect, and adjust the dimensions of entities.
Undo and redo actions.
Default keyboard shortcuts and mouse controls.
Supported SpaceBall or SpaceMouse devices.
ON THIS PAGE
Adding metadata by selecting a folder adds metadata to all the entities under the selected folder. Selecting a single entity or multiple entities of the same type adds metadata to the selected entities.
There are 3 types of metadata supported:
ON THIS PAGE
