Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Use the CFD 2D Mesh tool to generate hybrid grids containing hexa/penta/tetra elements in the boundary layer and tetra elements in the
core or fare field.
Automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids
or surfaces), without first creating a midsurface.
Use the Midsurfaces: Base Surfaces tool to specify a distance from the base surfaces of multiple solids that you wish to treat as if they were
continuous. This will help generate separate-but-aligned midsurfaces during extraction.
Use the Midsurfaces: Automatic tool to extract the midsurface of sheet metal stampings, molded plastic parts with ribs, and other parts that have
thickness clearly smaller than width and length.
The Rebuild tool streamlines the process of remeshing existing meshes to generate a new mesh with good quality and flow. The rebuild
mesh functionality utilizes the same parameter and criteria files used by BatchMesher to define the quality criteria and relevant mesh parameters. This algorithm saves significant time over the traditional
automesh and quality correction approach.
Adaptive wrap meshing is a useful utility to get a clean, water tight shell mesh out of 2D mesh containing several
intersecting parts and small gaps which do not need to be modeled.
Shrink wrap meshing is a method to create a simplified mesh of a complex model when high-precision models are not
necessary, as is the case for powertrain components during crash analysis.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Use the Midsurfaces: Pocket Imprint
tool to imprint pockets, fillets, and other geometry features from the source geometry onto
the midsurfaces.
Imprinting makes midsurface thickness calculations more accurate by creating mesh
boundaries that match the feature boundaries on the original solid, and improves the
meshing quality by capturing the features of the solid model.
From the 2D ribbon, click the Midsurfaces > Pocket Imprint tool.
Optional: On the guide bar, click
to define imprint options.
Select Lines or Surfaces from the Source
selector.
Select lines/surfaces.
You are not required to select the midsurface. HyperMesh automatically recognizes the midsurface
corresponding to the solid/surface component from which it was derived and
imprints the lines/surfaces on the midsurface component.
Optional: To manually select target surfaces, change the Target surfaces selection option
to Manual, activate the Target
selector on the guide bar, then select make your
selection.
