HyperWorks
HyperWorks
2023
  1. Home
  2. Interface with External Products
  3. HyperGraph Solver Interfacing
    Supported solvers in HyperGraph.
  4. Interfacing with OptiStruct
    This section discusses how the HyperGraph applications interface with the OptiStruct solver.
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
2023
HyperWorks
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
    • Change Solver Interfaces
      Load a different solver interface in the application.
    • HyperMesh Solver Interfacing
      Supported solvers in HyperMesh.
    • HyperView Solver Interfacing
      Supported solvers in HyperView.
    • HyperGraph Solver Interfacing
      • Interfacing with Abaqus
        This section discusses how HyperGraph interfaces with the Abaqus solver.
      • Interfacing with Nastran
        This section discusses how the HyperGraph applications interface with the Nastran solver.
      • Interfacing with LS-DYNA
        HyperGraph can read the following ASCII files and the corresponding information in binary format in binout from the LS-DYNA solver.
      • Interfacing with OptiStruct
        • HyperGraph Interface with OptiStruct
          This section explains how HyperGraph interfaces with the OptiStruct solver.
      • Interfacing with PAM-CRASH 2G
        This section discusses how the HyperGraph applications interface with the PAM-CRASH 2G solver.
      • Interfacing with Radioss
        This section discusses how the HyperGraph applications interface with the Radioss solver.
    • MotionView Solver Interfacing
      Solvers and translators supported in MotionView.
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023
  1. Home
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
