Nastran Model Input Reader
Supported Options
- By HM Comments
 - When this import option is selected, HyperView will:
- Create a component based on the HMCOMP NAME card
 - Move elements into component based on the HMMOVE card
- Read ANSA and PATRAN Comments
 - ANSA and PATRAN comments are supported during import.
 - Use New Element Pooling Scheme
 - Use this option to retain IDs from the model file while reading the model input as the solver file, which contain elements sharing the same ID space (for example: CQUAD elements sharing the same ID as RBE2/RBE3/RJOINT, etc.).
