Align and Project Elements
Use the Align/Project tool to project entities to lines, surfaces, or planes then remap and offset projected nodes.
![](../../../images/icons/icon_align_project.png)
Align to Lines
Use the Line tool to project nodes or points to a line along a user-defined direction or the normal to the line selected, then remap or offset over selected reference entities.
- Project source nodes on to a target line
Figure 3. - Project nodes on to a smooth line (smooth lines can be defined using the
location entity)
Figure 4. - Align nodes between start and end nodes
Figure 5. - Align nodes with respect to reference nodes
Figure 6. - Align + Remap
Figure 7. - Align + Offset
Figure 8.
Align to Surfaces
Use the Surfaces tool to project nodes, elements, lines and points onto a surface along either a user-defined direction or the normal to the surface selected.
Align to Planes
Use the Planes tool to project nodes, elements, lines and points onto a plane along a user-defined direction
