Joint
Joint
Class Joint()
Joint(parent='MODEL', name='Body_n', label='Body_n', active=True,
type='BallJoint', b1=None, b2=None, origin=None, align_meth1='Point', align_pt1=None,
align_vec1=None, align_meth2='Point', align_pt2=None, align_vec2=None,
align_type='Inplane', inplane_type='Inplane', inline_type='Origin', ujoint_meth1='SHAFT',
ujoint_meth2='SHAFT', ic_use_trans=False, ic_trans_disp=0, ic_trans_vel=0,
ic_use_rot=False, ic_rot_disp=0, ic_rot_vel=0, pitch=0, allow_compliance=False, isbush=False)
A Joint.
Joints create lower pair constraints. A lower pair is an idealized form of constraint where the constraint can be represented using two reference frames, or coordinate systems, belonging to two different bodies. The origin, axis, or plane of one reference frame is said to be constrained with respect to the origin, axis, or plane of another reference frame.
Method:
getAssociatedGraphics
Keyword Arguments
| Argument | Data Type | Description | Default |
| name | String | The variable name. | Joint_n, for next available integer n. |
| label | String | The descriptive label. | Joint_n, for next available integer n. |
| parent | Object | The parent. | MODEL |
| active | Bool | Used to activate or deactivate this entity. | True |
| type | Enum | The type. One of BallJoint, UJoint, TransJoint, RevJoint, InlineJoint, FixedJoint, InplaneJoint, CylJoint, Planar, CVJoint, AtPointJoint, OrientJoint, ParallelAxesJoint, PerpAxesJoint or ScrewJoint. | BallJoint |
| b1 | Body | The first constrained body. | None |
| b2 | Body | The second constrained body. | None |
| origin | Point | The origin. | None |
| align_meth1 | Enum | Alignment method for axis 1. Applies to type RevJoint, TransJoint, UJoint, InlineJoint, InplaneJoint, CylJoint, PlanarJoint, CVJoint, ParallelAxesJoint, PerpAxesJoint or ScrewJoint. One of Point, Vector. | Point |
| align_pt1 | Point | The point when align_meth1 is Point. | None |
| align_vec1 | Vector | The vector when align_meth1 is Vector. | None |
| align_meth2 | Enum | Alignment method for axis 2. Applies to type InplaneJoint, PlanarJoint, ParallelAxesJoint, UJoint, CVJoint or PerpAxesJoint. One of Point or Vector. | Point |
| align_pt2 | Point | The point when align_meth2 is Point. | None |
| align_vec2 | Vector | The vector when align_meth2 is Vector. | None |
| align_type | Enum | Alignment of planar and parallel joints.One of Inplane or Normal. | Inplane |
| inplane_type | Enum | Alignment of inplane joint. One of Inplane or Normal. | Inplane |
| inline_type | Enum | Alignment method for second axis of inline joint. One of Origin or Axis. | Origin |
| ujoint_meth1 | Enum | Orientation method for axis 1 of universal joint. One of SHAFT or CROSSPIN. | SHAFT |
| ujoint_meth2 | Enum | Orientation method for axis 2 of universal joint. One of SHAFT or CROSSPIN. | SHAFT |
| ic_use_trans | Bool | Translational initial conditions when true. Valid for joints of type TransJoint or CylJoint. | False |
| ic_trans_disp | Double | Initial translational displacement. | 0 |
| ic_trans_vel | Double | Initial translational velocity. | 0 |
| ic_use_rot | Bool | Translational initial conditions when True. Valid for joints of type RevJoint or CylJoint. | False |
| ic_rot_disp | Double | Initial rotational displacement of the joint. | 0 |
| ic_rot_vel | Double | Initial rotational displacement. | 0 |
| pitch | Double | The pitch for ScrewJoint. Pitch is the amount of translational displacement per revolution of the joint. | 0 |
| allow_compliance | Bool | Allow compliance. | False |
| isbush | Bool | Use as a bushing. | False |
Instances
| Instance | Type | Description |
| friction | Friction | The friction attribute to modify friction properties. |
| bush | Bushing | The bushing when isbush is True. |
Notes
1. The parent parameter can only be initialized by the constructor and should not be modified directly.
2. Only parent can be used as a positional argument in the constructor.
3. Instance is a reference to an entity. You cannot modify an instance, but can modify its properties.
Methods
- getAssociatedGraphics()
Get all the graphics that are associated with this object.
Returns:
List of all graphic associated with this joint.
Return type:
(list)
Joint Pair
Class JointPair()
JointPair(parent='MODEL', name='JointPair_n', label='JointPair_n', active=True, sym='NONE')
Joint pair containing left and right instances of singles.
Keyword Arguments
| name | String | The variable name. | JointPair_n, for next available integer n. |
| label | String | The descriptive label. | JointPair_n, for next available integer n. |
| active | Bool | Defines if entity is activated when True or deactivated when False. | True |
| sym | Enum | The symmetry of pair entity. Takes values 'LEFT' for left entity as leader, 'RIGHT' for right entity as leader or 'NONE' when it is not symmetric. | NONE |
Instances
| l | Point | The left joint. |
| r | Point | The right joint. |
Notes
Friction
Class Friction()
Friction(**kwds)
Utility class to hold and modify friction properties for a joint.
Keyword Arguments
| use_friction | Bool | Use friction properties when True. | False |
| transition_vel | Double | Specifies the velocity threshold for the transition from dynamic friction to static friction. | 0.1 |
| mu_dynamic | Double | The coefficient of friction when the slip velocity is greater than transition_vel. | 0.25 |
| mu_static | Double | The coefficient of friction when the slip velocity is less than transition_vel. | 0.3 |
| max_deformation | Double | Specifies the maximum creep that can occur in a joint during the stiction regime. Only for SolverMode ADAMS. | 0.01 |
| use_static | Enum | One of ACTIVE_STATIC or INACTIVE_STATIC. | ACTIVE_STATIC |
| effect | Enum | Specifies the frictional effect included in the friction model. One of STICTION_AND_SLIDING, STICTION_ONLY or SLIDING_ONLY. | STICTION_AND_SLIDING |
| preload_input | Enum | Specifies if force preload is an input to the friction model. One of PRELOAD or NO_PRELOAD. | PRELOAD |
| reaction_force_input | Enum | Specifies if joint reaction force is an input to the friction model. One of REACTION_FORCE or NO_REACTION_FORCE. | REACTION_FORCE |
| bending_moment_input | Enum | Specifies if bending moment is an input to the friction model. This property is applicable to revolute, translational, cylindrical and universal joints. One of BENDING_MOMENT or NO_BENDING_MOMENT. | BENDING_MOMENT |
| torsional_moment_input | Enum | Specifies if torsional moment is an input to the friction model. This property is applicable to translational joint only. One of TORSIONAL_MOMENT or NO_TORSIONAL_MOMENT. | TORSIONAL_MOMENT |
| f_preload | Double | Specifies the joint's preload friction force. Applicable for translational and cylindrical joints only. | 0 |
| t_preload | Double | Specifies the joint's preload friction torque. Applicable for revolute, cylindrical, universal and ball joints only. | 0 |
| ball_radius | Double | Specifies the radius of the ball joint. Applicable for ball joint only. | 1 |
| pin_radius | Double | Specifies the radius of the pin. Applicable for revolute, cylindrical and universal joints only. | 1 |
| friction_arm | Double | Specifies the moment arm used to compute axial friction torque. Applicable for revolute and universal joints only. | 1 |
| bending_reaction_arm | Double | Specifies the moment arm used to compute the contribution of bending moment on friction torque. Applicable for revolute and universal joints only. | 1 |
| reaction_arm | Double | Specifies the moment arm of the reaction torque. Applicable for translational joint only. | 1 |
| initial_overlap | Double | Specifies the initial overlap of the sliding bodies. Applicable for translational and cylindrical joints only. | 1000 |
| rot_constraint | Enum | Specifies the rotational constraint in the universal joint on which the friction acts. One of I_YOKE, Y_YOKE or BOTH. Applicable for universal joint only. | I_YOKE |
| overlap_delta | Enum | Specifies the change in overlap in the sliding bodies connected by the joint. One of INCREASE, DECREASE or CONSTANT. | CONSTANT |
| bristle_stiffness | Double | Specifies the bristle stiffness in the LuGre model. It models the stiffness resisting micro-deformation in the friction element. | 100 |
| damping_effects | Double | Specifies the LuGre damping coefficient for the stiction regime. | 0.316 |
| viscous_effects | Double | Specifies the coefficient for the viscous damping force that occurs when relative sliding actually begins. | 0.0004 |
Notes
You cannot create instances of the Friction class. This class is used to modify the friction properties of a joint.
Examples
Create and modify attributes of a Joint.
>>> from hw import mview
>>> #Create a Ball joint and references
>>> j1 = mview.Joint(name = 'j1', type = 'BallJoint')
>>> body1 = mview.Body(label = 'refbody')
>>> #Set values for attributes
>>> j1.b1 = body1
>>> j1.b2 = 'B_Ground'
>>> j1.origin = mview.getModel().P_Global_Origin
>>> #Get values of attributes
>>> j1.friction.use_friction
False
>>> #Set multiple values at once
>>> j1.friction.setValues(use_friction = True,mu_static = 0.5)
>>> #Get list of properties/atrributes for all types of joints
>>> j1.getPropertyNames()
['name', 'label', 'note', 'num', 'id', 'active', 'ifstate', 'varname', 'sym', 'type', 'b1', 'b2',
'origin', 'align_meth1', 'align_pt1', 'align_vec1', 'align_meth2', 'align_pt2', 'align_vec2',
'align_type', 'inplane_type', 'inline_type', 'ujoint_meth1', 'ujoint_meth2', 'ic_use_trans',
'ic_trans_disp', 'ic_trans_vel', 'ic_use_rot', 'ic_rot_disp', 'ic_rot_vel', 'pitch',
'allow_compliance', 'isbush', 'bush', 'friction', 'i', 'j', 'joint_i', 'joint_j']
>>> #Create a compliant joint
>>> j2 = mview.Joint(type = 'RevJoint',allow_compliance = True)
>>> j2.b1 = body1
>>> j2.setValues(b1 = body1,b2 = 'B_Ground',origin = 'P_Global_Origin')
>>> j2.align_meth1 = 'VECTOR'
>>> j2.align_vec1 = 'V_Global_Z'
>>> #Set bushing properties
>>> j2.isbush = True
>>> #Linear value of stiffness
>>> j2.bush.kx.lin = 100
>>> j2.bush.cty.type = 'CRV'
>>> #Nonlinear curve value for damping
>>> c1 = mview.Curve(x_type = 'VALUE',y_type = 'VALUE',x_value = [0,1],y_value = [10,20])
>>> j2.bush.cty.crv = c1
>>> #Set interpolation type and independent variable
>>> j2.bush.cty.int_type = 'CUBIC'
>>> j2.bush.cty.indep_var = '`TIME`'
>>> #These steps can be repeated for any type of joint, with associated properties
