Vector
Vector
Class Vector()
Vector(parent='MODEL', name='Vector_n', label='Vector_n',
active=True, x=1, y=0, z=0)
3D Vector.
angle, normalize
Keyword Arguments
| Argument | Data Type | Description | Default |
| name | String | The variable name. | Vector_n, for next available integer n. |
| label | String | The descriptive label. | Vector_n, for next available integer n. |
| parent | Object | The parent. | MODEL |
| active | Bool | Used to activate or deactivate this entity. | True |
| x | Double | The x component. | 1 |
| y | Double | The y component. | 0 |
| z | Double | The z component. | 0 |
Notes
1. The parent parameter can only be initialized by the constructor and should not be modified directly.
2. Only parent can be used as a positional argument in the constructor.
Methods
- angle(other, degrees=False)
Calculates angle between two vectors.
other str Name of the second vector. Can also be a python object. degrees Bool If True returns the angle in degrees. False Returns:
Angle between self and other.
Return type:
Double
- normalize()
Normalize the vector.
Returns:
Normalized vector.
Return type:
Vector
Vector Pair
Class VectorPair()
VectorPair(parent='MODEL', name='VectorPair_n', label='VectorPair_n', active=True, sym='NONE')
3D vector pair.
Keyword Arguments
| name | String | The variable name. | VectorPair_n, for next available integer n. |
| label | String | The descriptive label. | VectorPair_n, for next available integer n. |
| active | Bool | Defines if entity is activated when True or deactivated when False. | True |
| sym | Enum | The symmetry of pair entity. Takes values 'LEFT' for left entity as leader, 'RIGHT' for right entity as leader or 'NONE' when it is not symmetric. | ‘NONE' |
Instances
| Instance | Type | Description |
| l | Point | The left point. |
| r | Point | The right point. |
Notes
Instance is a reference to an entity. You cannot modify an instance, but can modify its properties.
Examples
Create a vector, modify its properties and perform different operations on the vector
>>> #Create a Vector and set its x, y and z component
>>> v1 = Vector(name='v_1', label='Vector_1', x=1, y=2, z=3)
>>> v2 = Vector(name='v_2', label='Vector_2', x=-3, y=0, z=1)
>>> #Unary minus
>>> v3 = -v1
>>> v3.x
-1
>>> v3.y
-2
>>> v3.z
-3
>>> #Addition
>>> v4 = v1 + v2
>>> v4.x
-2
>>> v4.y
2
>>> v4.z
4
>>> #Subtraction
>>> v5 = v1 - v2
>>> v5.x
4
>>> v5.y
4
>>> v5.z
2
>>> #Dot product of 2 vectors
>>> v1%v2
0
>>> #Cross product of 2 vectors
>>> v6 = v1*v2
>>> v6.x
0.169030850946
>>> v6.y
-0.845154254729
>>> v6.z
0.507092552837
>>> #Calculate angles between vectors
>>> v1.angle(v2)
1.5707963267948966
>>> v1.angle(v2, degrees=True)
90.0
>>> #Calculate magnitude of the vector
>>> v1.magnitude()
3.7416573867739413
>>> #Create a unit vector
>>> v7 = v1.normalize()
>>> v7.x
0.267261241912
>>> v7.y
0.534522483825
>>> v7.z
0.801783725737
>>> #Scale a vector with a factor
>>> v8 = v1*10
>>> v8.x
10
>>> v8.y
20
>>> v8.z
30
