ModalForce
Class ModalForce()
ModalForce(parent='MODEL', name='ModalForce_n', label='ModalForce_n',
active=True, b1=None, b2=None, load_selected=0, usr_type='SCALE', user=False)
A disturbed force on a flexible body that exists in the modal form in the flexible body H3D.
Keyword Arguments
| Argument | Data Type | Description | Default |
| name | String | The variable name. | ModalForce_n, for next available integer n. |
| label | String | The descriptive label. | ModalForce_n, for next available integer n. |
| parent | Object | The parent. | MODEL |
| active | Boolean | Used to activate or deactivate this entity. | True |
| b1 | Body | The flex body the distributed force is to be applied. | None |
| b2 | Body | The rigid body on which the reaction force acts on, when type is action reaction. Applicable only for ADAMS solvermode. | None |
| itype | Enum | The type of ModalForce. One of ACTION or REACTION. REACTION type of force is applicable only when solvermode is ADAMS. | ACTION |
| load_selected | Int | The selected load case as available in the flexible body H3D. | 0 |
| usr_type | Enum | One of SCALE or FORCE. Applicable when using user defined properties. | SCALE |
| user | Bool | Use user defined properties, if true. | False |
| usr_sub | Function | The expression passed to the user dll. When using solver expressions, Templex syntax (within ``) is used and all variables are enclosed in braces {} and the rest is treated as literal. | 'USER()' |
| local_funcname | String | The function/subroutine name. | 'MOTSUB' |
| use_local_dll | Bool | Uses a local function instead of default if True. | False |
| local_dll | File | The path of the local dll which has the local_funcname. | '' |
| local_func_type | Enum | The type of the user subroutine. one of DLL, PYTHON or MATLAB. | 'DLL' |
Instances
scale (Nonlinear) : The scale applied for the force. Defaults to :.
Readonly Properties
loadlist (Any) : The list contains the load case id as available in the flexible body H3D. Load case ID generally matches with the ID specified in the finite element deck (.fem in case of OptiStruct) that was used to generate the flexible body. Defaults to None.
Examples
>>> # Import mview module
>>> from hw import mview
>>> mf = mview.ModalForce()
>>> m.itype
'ACTION'
>>> bf1 = mview.Body(name="bflex_1, "useflex=True)
>>> bf1.flex.MotionSolve.graphic_file = r"C:/Altair/mv_hv_hg/mbd_modeling/flexbodies/modalforce/gra_forecanard.h3d"
>>> mf.b1 = bf1
>>> mf.b1.name
'bflex_1'
