Add Items
Add document and presentation items to the report.
Use the Report Browser to create, execute, and export Document and Presentation reports.
An overview of Layout template.
Generate predefined Session report and Model Summary report.
Define Report group enables user to perform report actions in just one click.
Add document items to report.
Add presentation items to report.
Modules are used to perform specific operations in a report in automated ways, and provide the output in the prescribed format per module logic.
Synchronize the exported report with new changes in the Report structure or content.
Modify the layout document and select the report type.
Custom tasks in report generation.
