Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Use the Report Browser to create, execute, and export Document and Presentation
reports.
From the menu bar, click Report to open
the Report Browser.
The Report Browser has three sections:
Toolbar
The Report Browser toolbar allows you to perform following actions:
Tree Area
The Report Tree Area allows you to add items and create a report tree structure,
which also can be referred to as a table of contents.
Entity Editor
In a Report, each entity has associated properties, which directly or indirectly
define the inputs. These properties can be accessed from the Entity Editor in the Report tab.
Filepath Storage
Select the file path information storage type.
Available options are
Absolute
If selected at Report level, then absolute paths are shown
in all items or modules wherever there is a file path.
Relative
If selected at Report level, then all the paths in items or
modules are shown relative to Working Directory.
Export File Formats
Report supports the following input file templates formats:
DOCX
DOCM
PPTX
PPTM
The supported output file formats are as follows:
DOCX
DOCM
PPTX
PPTM
PDF, ODT, and ODP
Note: These formats are available only with a word
processing application.
HTML
Open Report file are export
Select the option to open the report file after export.
