Geometry Cleanup
In this tutorial, you will learn how to cleanup geometry and conduct midsurfacing.
- Evaluate the integrity of a model
- Use the Surface repair to find, review, and fix any geometric errors in the model surfaces
- Identify issues
- Remove free edges
- Create closed shell
Evaluate Model Integrity
In this step, you will evaluate the model integrity using the View Controls toolbar.
Find, Review, and Fix Geometric Errors
In this step, you will use the Surface Repair tool to find, review, and fix any geometric errors in the models surface.
Identify Issues
- Select the associated tool from the secondary toolset.
- From the legend, click the error type.
