SS-V: 1040 Clamped Thin Plate
Test No. VS05 Obtain the displacement at the center of a clamped thin plate for concentrated load and uniform pressure load.
Definition
A square plate clamped on four edges (Figure 1) is subjected to the following loads (Figure 2):
- uniform pressure
 - concentrated load
The units are IPS.
- Properties
 - Value
 - Modulus of Elasticity
 - 1.7472e+7 psi
 - Poisson's Ratio
 - 0.3
Results
| Theory (Kirchoff's Plate Bending Model) | SimSolid | % Difference | |
| Uniform load | 1.2600E-06 | 1.2670E-06 | 0.56% |
| Point load | 5.6000E-06 | 5.6080E-06 | 0.14% |
