Test No. VS10 Find the stress concentration in a filleted
    notch.
    Definition
      The large shaft face is fixed.
      The load is 1MPa external pressure on the smaller shaft face. Run
        analysis with 5 adaptive passes and "Adapt to features" on.
      The units are SI.
      The model parameters are:
            - Parameters
            - Value
            - D
            - 120 mm
            - d
            - 60 mm
            - r
            - 3 mm
            - D/d
            - 2
            - r/d
            - 0.05
    Results
The reference solution is given
          by:
(1)
The following table summarizes the stress results.
                Theory  |
                SimSolid |
                % Difference |
                | SZ Stress [MPa] |
                2.6000E+00 |
                2.4460E+00 |
                -5.92% |
