SS-V: 1110 Notched Plate
Test No. VS12 Find Sx stress in the notch and top face of a notched plate.
Definition
The left face is fixed. The load is a moment of 500 lbf-in applied to right face.
The units are IPS.
- Parameters
 - Value
 - Length
 - 16 in
 - Width
 - 5 in
 - Plate thickness (r)
 - 0.5 in
- Properties
 - Value
 - Modulus of Elasticity
 - 30e+6
 - Poisson's Ratio
 - 0.3
Results
| Reference Solution | SimSolid | % Difference | |
| SXX Stress in Notch [psi] | 7.3100E+02 | 7.6890E+02 | 5.18% |
| SXX Stress along top face [psi] | 2.4000E+02 | 2.4001E+02 | 0.00% |
