Test No. VS16 Find the critical compression load at
        which the cantilever beam buckles.
        Definition
            Dimensions: L = 1000 mm, b = 20 mm, h = 20 mm
            Where,
                        - b
                        - Breadth of the rectangular section.
                        - h
                        - Height of the rectangular section.
            The material properties are:
                        - Properties
                        - Value
                        - Modulus of Elasticity
                        - 2.1e11 pa
                        - Poisson's Ratio
                        - 0.3
        Results
The following table summarizes
                the critical load.
                                Reference KN* |
                                SimSolid KN |
                                | Critical Load |
                                6.90 |
                                6.904 |
*The reference result is calculated by:
                Where,
                        - Elastic modulus.
                        - Area moment of inertia.
                        - Length of the beam.
                        - Effective length factor = 2 for cantilever beam.
