Test No. VS13 Find the max displacement and stress for a
    pinned beam with load at the midpoint.
    Definition
      The units are SI.
    Results
      The reference solution for max displacement is given by:
(1)
      Where,
(2)
      Where,
      The following table summarizes the displacement and stress results.
                Reference |
                SimSolid |
                % Difference |
                | Max Displacement [mm] |
                1.0714E+00 |
                1.0764E+00 |
                0.46% |
                | Max Stress [MPa] |
                1.5000E+02 |
                1.5011E+02 |
                0.07% |
