Define Volume Probes
Use the Probes tool to define volume probes.
When volume probes are defined, HyperMesh CFD writes all volume variables to disk at the request output interval.
Create volume probes.
From the Setup ribbon, click the
Output
tool.
Figure 1. -
From the secondary tool set, click the volume probes of the
Probes tool.
Figure 2. - Click in the modeling window to create probes.
Output
tool.
- Optional:
Define volume probe settings in the microdialog.
Define the start iteration or start time.
To define the start time, see step 3 of Define Surface Probes.
Define the output interval, refinement level, or target
frequency.
To define the refinement level, see step 5 of Define Surface Probes. To define the target frequency, see step 6 of Define Surface Probes.
Figure 3. -
- Optional:
Import and export volume probes.
- From the legend in the top-left of the modeling window, right-click the active probe set and select Probes table from the context menu.
In the dialog, select
to import volume probes.
to export volume probes.
For more information, see Import, Export, and Edit Output Controls. - Optional:
Create probes from a rake.
For more information, see Create Volume Probes from Rake.
Change the color of probes.
- From the legend in the top-left of the modeling window, right-click the active probes and select Change color from the context menu.
Use the color picker to edit the color of the selected probes.
Tip: Create custom colors within the color picker by clicking
Move probes in the modeling window.
- Select a probe.
In the microdialog, select
Use the graphical manipulators to move the probe.
Figure 4.
From the guide bar, complete one of the following:
- Select
to confirm your selection and continue creating
sets of probe points. - Select
to
confirm your selection and exit the tool.
- Select
