Create Volume Probes from Rake
Use the Probes tool to create probes from a rake.
Use the Volume Probes tool to draw polylines.
From the Setup ribbon, click the
Output
tool.
Figure 1. -
From the secondary tool set, click the volume probes of the
Probes tool.
Figure 2. - From the guide bar, select Rake.
- Click in the modeling window to create rakes.
- From the guide bar, complete one of the following:
- Select
to confirm your rake and continue creating
rakes. - Select
to
confirm your rake and exit the tool.
Output
tool.
- Optional:
Define rake settings in the microdialog.
Define the start iteration or start time.
To define the start time, see step 3 of Define Surface Probes.
Define the output interval, refinement level, or target
frequency.
To define the refinement level, see step 5 of Define Surface Probes. To define the target frequency, see step 6 of Define Surface Probes.
Figure 3. -
Move rake points in the modeling window.
In the microdialog, select
- Select an existing point and use the graphical manipulators to move the rake points.
Figure 4. -
Move rakes in the modeling window.
- Click the center of the rake to place the graphical manipulator.
- Drag the line while left-clicking the center point of the graphical manipulator.
Figure 5. - Optional:
Import and export probes.
- From the legend in the top-left of the modeling window, right-click the active probe set and select Probes table from the context menu.
In the dialog, select
to import volume probes.
to export volume probes.
For more information, see Import, Export, and Edit Output Controls.
