Extend
Extend or shorten an entity of a sketch curve.
Click the Extend icon.
- Click an entity to select it.
Move the mouse to preview the extended or shortened entity, and then click to
extend or shorten the entity.
Tip: If in the previous step you selected an entity (A) that intersects with another entity (B), you can click B near the intersection point to extend or shorten A at that intersection point.
Table 1. Example 1: Extend Table 2. Example 2: Shorten - Right-click and mouse through the check mark to exit, or double-right-click.
Tip:
- This tool does not currently work on Splines.
