Intersect
Extract curves resulting from the intersection of the sketch plane with selected parts.
Create Intersection Curves
- The origin of the plane becomes the origin of the sketch. Once the sketch is created, additional parts, solids, or surfaces can be selected. The plane definition is locked for that particular sketch.
- To convert an intersection line to a sketch curve, right-click the intersection line and select Create Curve.
