HyperWorks
HyperWorks
2023
  1. Home
  2. Plot Data
  3. Line Chart
  4. Define
    Create and edit curves.
  5. Insert Data Point Values
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
2023
HyperWorks
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
    • Working with Plots
      Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
    • Line Chart
      • Create Curves by File
        Plot curves for multiple runs and multiple subcases for a component.
      • Define
        • Data Sources
        • MATLAB Interface
        • Dynamic Curve Names
          When creating a curve using the Create Curves by File dialog, the curve name is defined by a Templex expression instead of a fixed string.
        • Add a Curve
        • Copy and Paste Data Point Values
        • Cut, Copy, and Paste Curves
        • Cut Data Point Values
        • Define a Range
        • Display the Curves Dialog
        • Edit a Curve with File as a Data Source
        • Freeze a Curve
        • Freeze and Unfreeze a Vector
        • Insert a Vector into an Active Expression
        • Insert Data Point Values
        • Reference a Curve in the Active Window
        • Rename a Curve
        • Select a Windowing Function
        • Use File as a Data Source
        • Use Math as a Data Source
        • Use Values as a Data Source
        • Turn a Curve On or Off
      • Math
        Create macros that produce curves and notes for plots.
      • Edit
        Edit curves within a specified range and orientation.
      • Values
        Retrieves individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
      • Statistics
        Calculates statistics over a specified range on a curve.
      • Datums
        Add horizontal and vertical datum lines to plots.
      • Notes
        Annotate plots using notes.
      • Move
        Curve scaling, offsets, and axis assignments can be applied to multiple curves using the Move panel.
    • Bar Chart
    • Complex Chart
    • Polar Chart
    • Vector Chart
    • Radar Chart
    • 3D Chart
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023
  1. Home
  2. Plot Data
  3. Line Chart
  4. Define
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  1. From the Define panel, select Values.
  2. Select a point from the table.
  3. Click Insert.
    A new row is added above the selected row. The data values are both zero by default, allowing you to enter new values.
