Maximum Strain and Maximum Stress Criteria
These criteria do not consider any interaction between different stress (strain components).
- σ1≥XTσ1≥XT or σ1≤−XCσ1≤−XC
- σ2≥YTσ2≥YT or σ2≤−YCσ2≤−YC
- τ12≥Sτ12≥S
- Xt,XcXt,Xc are the maximum allowable stresses in the 1-direction in tension and compression,
- Yt,YcYt,Yc are the maximum allowable stresses in the 2-direction in tension and compression,
- SS is the allowable in-plane shear stress
Relevant failure index is evaluated as per the following equation:
Findex=max[σ1X,σ2Y,τ12S]Findex=max[σ1X,σ2Y,τ12S]
being X=XTX=XT or X=XCX=XC if σ1≥0σ1≥0 or σ1<0σ1<0 and the same for YY .
The approach for maximum strain criterion is the same as per the maximum stress on, but with the corresponding strains in the condition for failure to be taken into account.
MaxStrainFT(tensor,xt,xc,yt,yc,s,sets,plies,elems,parts,props,pool_name,layer_index,opt_str)
Arguments
- tensor
- Stress table
- xt
- Allowable tensile stress/strain in ply material direction 1
- xc
- Allowable compressive stress/strain in ply material direction 1
- yt
- Allowable tensile stress/strain in ply material direction 2
- yc
- Allowable compressive stress/strain in ply material direction 2
- s
- Allowable in-plane shear stress/strain
- sets
- Set table (D=NULL)
- plies
- Ply table (D=NULL)
- elems
- Element table (D)
- parts
- Part table (D)
- props
- Property table (D)
- pool_name
- Pool name (D=@current_pool)
- layer_index
- Layer index (D=@current_slice_index)
- opt_str
- This is an optional argument, which can passed if needed (D=option).
