Tsai-Wu Criterion
The Tsai-Wu theory defines the ply failure index as below:
Findex=(1XT1XC)σ1+(1YT1YC)σ2+σ21XTXC+σ22YTYC+τ212S2+2F12σ1σ2Findex=(1XT1XC)σ1+(1YT1YC)σ2+σ21XTXC+σ22YTYC+τ212S2+2F12σ1σ2
Where:
  • Xt,Xc are the maximum allowable stresses in the 1-direction in tension and compression,
  • Yt,Yc are the maximum allowable stresses in the 2-direction in tension and compression,
  • S is the allowable in-plane shear stress
  • F12 is a factor to be determined experimentally
TsaiWuFT(tensor,xt,xc,yt,yc,s,f12,sets,plies,elems,parts,props,pool_name,layer_index,opt_str)
Arguments
tensor
Stress table
xt
Allowable tensile stress in ply material direction 1
xc
Allowable compressive stress in ply material direction 1
yt
Allowable tensile stress in ply material direction 2
yc
Allowable compressive stress in ply material direction 2
f12
F12 experimental factor
s
Allowable in-plane shear stress
sets
Set table (D=NULL)
plies
Ply table (D=NULL)
elems
Element table (D)
parts
Part table (D)
props
Property table (D)
pool_name
Pool name (D=@current_pool)
layer_index
Layer index (D=@current_slice_index)
opt_str
This is an optional argument, which can passed if needed (D=option).
Tsai-Wu Reserve Factor
Considering the above expression for the Failure Index if we set:
A=σ21XTXC+σ22YTYC+τ212S2+2F12σ1σ2
B=(1XT1XC)σ1+(1YT1YC)σ2
C = 1
Being k a given factor of safety, then the reserve factor formula can be evaluated as below:
RFTsaiWu=B±B24AC2ak
TsaiWuRF(tensor,xt,xc,yt,yc,s,f12,FoS,sets,plies,elems,parts,props,pool_name,layer_index,opt_str)
Arguments
tensor
Stress table
xt
xc
yt
yc
f12
FoS
Factor of Safety (D=1.0)
s
sets
Set table (D=NULL)
plies
Ply table (D=NULL)
elems
Element table (D)
parts
Part table (D)
props
Property table (D)
pool_name
layer_index
opt_str
