Undo All Morphs
Undo all morphs and return to the original state of the model.
This can be accomplished in the following ways:
  • From the Morph ribbon, Shapes tool group, click the Undo All Morphs tool.
  • In the Edit Shapes dialog, click .
  • Press Shift + Ctrl + Z. To redo all morphs, press Shift + Ctrl + Y.
Note: Any morphing performed on a saved model cannot be undone when the model is reloaded. Be sure to undo all the changes made to the model before saving it if you wish to preserve the model's original shape.
