Set Biasing
Change the biasing factors associated with each handle.
- From the Morph ribbon, click the arrow next to the Morph tool set name and select Set Bias.
- In the Morph Set Bias dialog, select handles for which you wish to apply biasing and click .
- For Bias, enter a value.
- Select the Make Retroactive check box to adjust the morphs currently applied to the model to reflect the new biasing factors.
- Select a biasing style.
- Click Update.
