Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include
file in relation to the full model in order to avoid ID duplication.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction,
transforming results, defining material orientation, and many other operations.
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on
the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type,
the tool generates contacts based on set segments or node and element combinations.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Multiple Checks perform multiple checks using a single interface.
If the Offset check is ON, CAD data will be offset using thickness value. Offset CAD
data will be used to check all other checks. Check and Reports are sequentially
executed for each check. Offset, Intersection, Spotweld, Connection, Free Part check
uses Base Model selection alone and ignores Variant model selections. The comparison
function uses both Base Model and Variant Model selections. The check item's input
rules are as per individual checks explained in respective check functions.
In the Comparison Browser, right-click and select Check > Multiple_Checks from the context menu.
The Model Verification dialog opens.
Upload the base model using the Base Model options.
Select an import type.
Select a data type.
Navigate to the model to import.
Upload the variant model using the Variant Model(s) options.
Select a data type.
Select the type of checks to perform, and define additional settings as
needed.
In the Report Path, navigate to the directory where the reports generated by
the Model Verification tool will be stored.
In the Project Name field, enter a name for the project.
In the Slide Number field, enter a starting number of the slides to use in the
PowerPoint report.
For example, if you enter a value of 1 for the slide
number, then the slide numbers in the report starts from 0001.
Choose a method for running the model.
Choose Interactive to run the model in the same
HyperMesh session.
Choose Background to launch a new HyperMesh session in batch mode and perform the
operation. The Background run mode is faster than the Interactive mode and
also allows you to utilize multiple processors that are available on the
machine to complete the operation faster. Each pair of models are divided
and handled in multiple HyperMesh sessions
depending on the number of processes selected.
For Action, choose to an operation to perform.
Choose Check to only perform a check.
Choose Report to generate a PowerPoint
report.
Choose Both to perform a check and generate a
report.
