Warn Upon Entity Type Change
Display a warning dialog when changing information in the Entity Editor.
Explore the user interface.
View controls enable you to control the view and display of your model in the modeling window.
Quickly find and open the tools and browsers that are available from the ribbons, as well as create entities and solver cards.
Select and deselect entities to modify with other tools. Selected entities are outlined to indicate their selection state.
Translate, rotate, and align the model.
Use the Measure tool to measure length, angles, radii, areas, volumes, centers of gravity, and bounding boxes.
Learn how to manipulate entities.
Learn the basics of working with entities.
Learn how to work with entities using the Entity Editor.
Every entity is assigned solver specific data, which you can modify using the Entity Editor.
Create, edit, and assign new entities to an existing entity or group of entities in the Entity Editor.
In the LS-DYNA, OptiStruct, and Radioss user profiles, certain entities can be defined with parameters in the Entity Editor.
Filter the entities that are not applicable to the entity displayed in the Entity Editor.
Set entities are used to define and store lists of entity IDs for a specific entity.
Define the mandatory, default value, and/or hidden state settings for entity attributes.
Use the tools in the Home ribbon group menu to transform, mirror/reflect, and adjust the dimensions of entities.
Add metadata to all types of entities. The added metadata can be saved to an *.hm file.
Undo and redo actions.
Default keyboard shortcuts and mouse controls.
Supported SpaceBall or SpaceMouse devices.
