Select Entities
Window Selection Settings
Change window selection settings from the modeling window right-click context menu.
Available in HyperMesh, HyperView, and HyperGraph.
Figure 3.
- Window Select Disabled - Disable window selection.
Allows for fast clicking without the risk of dragging a mini window.
(HyperMesh only)
- Window Shape - Change the shape of the selection window when you drag your mouse.
- Window Select Mode - Select entities that are inside,
outside, or intersecting the window shape.Note: Intersection is available for elements, lines, and surfaces.
(HyperMesh only)
- Only Select Visible - Only select visible entities.
