Inspire revolutionizes and democratizes implicit modeling for engineers and designers by addressing five common criticisms
of existing implicit modeling methods.
Learn how to use the Visualization Quality and Meshing Settings to manage compute times, the visual appearance, and
the geometric accuracy of implicit and mesh geometry when working with Inspire Implicit Modeling. This includes working in Implicit Modeling, converting other geometry formats in Implicit Modeling,
and meshing implicit geometry for export or other downstream processes.
Create simple geometric shapes that can be used for repetitive tasks or combined into more complex shapes. Implicit
primitives include a cuboid, cylinder, and sphere.
Fill a body with a surface lattice, which is a cellular structure constructed from one or sometimes two surfaces.
The body can be a Parasolid, STL, PolyNURBS, or implicit geometry.
Fill an implicit body with a planar lattice, which is a 2.5D cellular structure with a clearly defined 2D cross-section
that is drawn or extruded along the third dimension.
A detailed description of how fields are used in Implicit Modeling within Inspire, with videos and illustrative examples that will help you think intuitively in terms of field-driven design.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
Why Choose Inspire Implicit Modeling? Inspire revolutionizes and democratizes implicit modeling for engineers and designers by addressing five common criticisms of existing implicit modeling methods.
Flexible Parameter Controls
In Inspire, you can assign and edit implicit modeling parameters in multiple ways.
