Invert Implicit Geometry
Swap the "inside" and "outside" of an implicit body by reversing the sign of all scalar values in the underlying field.
On the Implicit Modeling ribbon, select the
Invert tool.
- Optional: For Visualization Quality, select from Low to Very High quality, which corresponds to a low to very high density of elements. A higher quality produces sharper geometry features but is more computationally intensive. When creating a complicated function, it’s recommended to work using a lower quality and then switch to a higher quality after the function is complete.
- Select an implicit body to invert.
- Select a second implicit body as the mask, which determines the volume of the selected body that the inversion operates on.
- Click OK.
