Display axial force, shear force and bending moment on the bolts. The output is
        available along different sections of the bolt that are defined by connections with
        neighboring parts. Maximum forces/moments across all the sections are also
        output.
                In the Project Tree, click the Analysis Workbench.
                On the workbench toolbar, click .
The Bolt internal forces dialog opens and displays
                    a table with axial, shear forces, bending moment and torque acting on the bolts.
                    Each row lists maximum forces/moments across all the sections for each
                    bolt.
                Select any column header to sort the table by that header.
                Expand any row to view the output at sections along the bolt.
- Optional:
                Use the check boxes for force, moment, and label to toggle the display of
                    respective vectors and labels in the modeling window.
- Optional:
                Click Save csv  to save the output to a
                        .csv file.
