Display Rivet Forces
Display a table of loads on a rivet.
- In the Project Tree, click the Analysis Workbench.
 - On the workbench toolbar, click .
                Navigate the table in the following ways:
- Select any column header to sort the table.
 - Select any row to display a Rivet forces summary along with the force and moment vectors.
 - Group select multiple rows using Shift + Control to sum the forces and display resultant force and moment vectors about the center of gravity (COG).
 - Optional:
                Save the loads on the rivet to a .csv file.
- Click Save to CSV and choose Save selected or Save all.
 - In the dialog, enter a file name and select a save location.
 - Click Save.
 - Optional: Use the check boxes for force, moment, and label to toggle the display of respective vectors and labels in the modeling window.
