Display axial force, shear force and bending moment on the bolts. The output is available along different sections
of the bolt that are defined by connections with neighboring parts. Maximum forces/moments across all the sections
are also output.
The Bookmark Browser allows you to capture images of your simulation modeling and results, caption the images, and export your gallery
as image and/or animation files.
You can export deformed shape in ssg/stl format for all parts in a given Project Tree branch.
To access the dialog, in the Project Tree right-click any
Structural analysis Results branch and select
Export from the context menu.
You can export both true deformation and scaled deformation. To export scaled
deformed shape, clear the True deformation check box. Figure 1.
Use any real number for scale factor. A scale factor of
0 will export an undeformed shape.
You can export deformed mode shape for modal analysis by right-clicking on the
Results branch and selecting
Export in the context menu.
You must plot results to activate this function.
To export a deformed shape
for modal analysis, you should enter a maximum deformation as the
displacements are normalized in modal analysis. Figure 2.
