View Spot Weld Fatigue Results
Display a table of spot weld fatigue results in SN fatigue analyses with spot welds present in the design study.
- In the Project Tree, open the Fatigue Analysis Workbench.
 - On the workbench toolbar, click the .
                Navigate the table in the following ways:
- Select the results type
 - Select the event
 - In the Spot welds section, view Max damage or Min life for each spot weld.
 - Select any row in the spot welds section to view the damage/ life at the nugget and the connected sheets.
