Display Results Graph
Show a graph of a quantity of interest along a path of a part surface.
- On the Project Tree, open the Analysis Workbench.
                On the Analysis Workbench
                    toolbar, click
 (Results plot).
             - In the drop-down menu, click the desired plot.
                Click
 (Results graph).
                In the modeling window, pick points on a single part of
                    the model.
                In the Result graph dialog, a graph support polyline is built using your selected points. Segments of the polyline are projected on the part, and the quantity of interest is evaluated along the projected path. Projection direction is perpendicular to the monitor screen. The graph is dynamically updated with every additional picked point.Note: You may rotate and translate the part between the point picks, the next segment is always projected onto the part in its current position.
 - Optional:
                Choose another quantity from the
 (Results plot) list to automatically update the graph to show a different
                    quantity.
