View Spot Weld Resultant Forces
Display a table of spot weld resultant forces.
- On the Project Tree, open the Analysis Workbench.
 - On the workbench toolbar, select .
                Navigate the table in the following ways:
- Select any column header to sort the table.
 - Select any row to display a spot forces summary along with the force and moment vectors.
 - Group select multiple rows using Shift + Control to sum the forces and display resultant force and moment vectors about the center of gravity (COG).
 - Optional:
                Save the spot weld resultant forces to a .csv file.
- Click Save to CSV and choose Save selected or Save all.
 - In the dialog, enter a file name and select a save location.
 - Click Save.
