View Fatigue History
Review fatigue history for each event at points of interest.
- In the Project Tree, open the Fatigue Analysis Workbench.
                On the workbench toolbar, select
 Fatigue History.
             - Select the event.
 - Select the response type.
                Choose one of the following options:
Option Steps Pick point - Select the Pick point radio button.
 - Select the desired points in the modeling window.
Choose datum point set This option is only available if datum points are present in the model. - Select the Choose datum point set radio button.
 - In the dialog, select a point set from the drop-down menu.
 - Click Evaluate to view the stress time response for the selected point.
                Pick a point on the graph to view the stress value at specific point of the
                    event history.
                The channel - loadcase contribution along with the amplification factors is listed for the specific point.
 - Optional: Click Create analysis to create a structural linear subcase with amplified loads from the contributed loadcases.
