Plot Dynamic Reaction Force
View dynamic reaction forces.
- Project Tree, select a Dynamic analysis branch to open the Analysis Workbench.
                On the workbench toolbar, select the
 (Reaction/contact force) icon.
             - In the dialog, select either the Supports tab or the Connections tab.
 - Select supports/connections from the list in the dialog.
 - Select a Reactions type from the drop-down menu.
 - Optional: If plotting multiple forces, you can select the Show each plot in separate window check box to create multiple plots.
                Click Evaluate.
                A new dialog will open showing a graph of the chosen force. You can use the radio buttons in this dialog to change Y-axis scale.
