Adds the simulation to the advanced query.
Creates BestView entries for every hotspot found by the advanced query.
Gets the ID of the advanced query.
Gets the label of the advanced query.
Gets the numeric format from the advanced query.
Gets the numeric precision from the advanced query.
Gets the selection set handle which holds the IDs of the result output.
Gets the output query string.
Gets the rule of the advanced query.
Gets the scalar define ID.
Gets the search options status from the advanced query.
Gets the list of search options from the advanced query.
Gets the list of simulations applicable for the advanced query.
Gets the subcase list applicable for the advanced query.
Gets the values from the advanced query.
Removes the simulations from the advanced query.
Sets the label to the advanced query.
Sets the numeric format for output values.
Sets the numeric precision for output values.
Sets the query string in the advanced query.
Sets the query logic to the advanced query.
Sets the scalar define ID.
Sets the search options status to the advanced query.
Writes the output data to files.
ON THIS PAGE
ON THIS PAGE
